Date/Time: Sun, 09 Feb 2025 03:12:29 +0000
MFE/MAE
View Count: 1898
[2020-08-07 02:09:18] |
User425645 - Posts: 113 |
Hello, are you guys able to add MFE & MAE to the trade statistics tab? Jigsaw has this and is very helpful (although their platform sucks) for recording trades. thanks for consideration.
[2020-08-07 02:16:21] |
also, on a slightly unrelated note, why is jigsaws DOM slightly faster then sierra charts? i've seen a couple tests on it and i know a few of my friends only went to jigsaw because of that. Thanks for your time
[2020-08-07 04:40:09] |
This is already supported and always has been: Trade Activity Log: Trade Statistics Fields Descriptions The naming is different. For the second question this is controllable: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Also refer to: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading And you really should switch to the Sierra Chart order routing service for complete order fill history: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
