Date/Time: Thu, 19 Sep 2024 01:02:47 +0000
ACSIL: Lines (using s_tool) do not show in second chart
View Count: 1125
[2014-02-01 05:51:50] |
User40117 - Posts: 56 |
hello, An indicator draws horizontal lines in a chart. I would like the lines to show up in another chart. Although i have defined the chart number in the settings to display the drawings, the lines from my studie are not shown, manually drawn lines however are shown in the second chart. Is it possible to show lines created by a study in another chart ? i tried Tool.AddAsUserDrawnDrawing = 1; They are individual lines now, but that doesn't seem to help either... |
[2014-02-04 17:15:19] |
This can be done but you need to use the s_UseTool::ChartNumber member to put the drawing on another chart: http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html We have tested this and confirmed it does work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
