Date/Time: Sat, 22 Feb 2025 09:21:38 +0000
FXCM
View Count: 677
[2020-08-06 17:03:42] |
grantx - Posts: 244 |
Has Sierra chart removed all support for trading through FXCM?
[2020-08-06 18:34:54] |
You can but we do not want to add more users onto FXCM. We recommend using LMAX instead: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-28 23:18:32] |
cfuture - Posts: 68 |
SC is recommending using LMAX. I just chatted with LMAX. They mentioned to me something about IB(introducer brokers). Does SC have a list of such entities?
Date Time Of Last Edit: 2021-01-28 23:20:16
