Date/Time: Sun, 09 Feb 2025 03:22:03 +0000
trades time frame
View Count: 532
[2020-08-06 00:56:38] |
User425645 - Posts: 113 |
Hello, if someone says they have their number bar chart is set to "1000 trades" what does that mean? i can't seem to find "trades" in the chart settings graph type. Thanks in advance
[2020-08-06 10:18:58] |
mpro - Posts: 44 |
Number of Trades
Bildschirmfoto 2020-08-06 um 12.18.07.png / V - Attached On 2020-08-06 10:18:39 UTC - Size: 76.76 KB - 208 views |
[2020-08-06 18:45:49] |
Refer to the information here for this Chart Setting: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-06 18:45:56
