Date/Time: Sun, 09 Feb 2025 02:43:21 +0000
custom Trading shortcuts... specify size?
View Count: 702
[2020-08-05 22:12:26] |
HeyUgly - Posts: 251 |
is there a way in the Trading keyboard shortcuts to specify size? i dont see it say i want a hotkey to be a Buy Ask 10 contracts? or Buy ASK 5 contracts SELL BID 3 contracts etc? i dont see a way to specify the size in the shortcut menu? maybe its there and i dont see it thanks in advance |
[2020-08-06 18:28:00] |
You can set Keyboard Shortcuts for the quantity buttons on the Trade Window. Refer to the information here: Basic Trading and the Trade Window: Main/C >> Order Quantity Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
