Date/Time: Sat, 26 Sep 2026 11:12:56 +0000
Newbe question....
View Count: 1668
[2014-02-01 00:58:17]
Auspicatum - Posts: 46
I have a question, as a newbe. But first I must say that this software is excellent. I can tell it was designed
or modified by traders.
Anyway, While trying to replay data, on multiple charts, with multiple time frames for each symbol...
they appear to not match up correctly, at the latest price. Granted they are close, (seems to be within 20 pips or so)...
but not always...
So I made sure to have all the dates match up for the data loaded in each chart. They are all intraday charts.
What else can be done to get the latest prices to align. It's no good if it shows what occurs already on one chart, but not the other.
Thanks again for the support !
[2014-02-01 01:28:32]
Sierra Chart - Max - Posts: 5971
Thank you for the comments.
Have you reviewed the Replay Documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#AllChartsInChartbook
Which Replay Mode are you using?
Sierra Chart Support
[2014-02-02 20:38:34]
On the Replay Window make sure you disable Skip Empty Period. And make sure you have For All Charts in Chartbook enabled also on the Replay window. This is all you should need to keep the charts synchronized.
If there still is a problem we will need to run a test.
[2014-02-04 09:18:03]
Yep, that was it. looks like the issue was that it was not running in "Accurate Trading System Backtest Mode"(found on the pop-up window after clicking "Replay Mode") . As of now, the prices appear
aligned.
Thanks for the hint and..
Thank you for your time !
Date Time Of Last Edit: 2014-02-04 09:20:50
