Date/Time: Sun, 09 Feb 2025 01:19:07 +0000
support
View Count: 463
[2020-08-05 17:37:24] |
User474865 - Posts: 1 |
hai , I am trading from India ,in NSE futures and options and MCX ,since I came to know about the sierra charts ,I want to purchase the chart ,but can you tell how can I use this chart ,is this useful in Indian Markets ,who will provide me the data thank you |
[2020-08-05 17:44:38] |
Hammerhead - Posts: 14 |
Hi, The information contained at the following link might help: Global Data Feeds (India) Data Service Regards, |
[2020-08-05 19:22:33] |
Yes you will want to use this data feed: Global Data Feeds (India) Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
