Date/Time: Thu, 17 Sep 2026 12:19:48 +0000
[User Discussion] - ADD- $nshf
View Count: 1678
| [2014-01-31 22:41:18] |
| User41056 - Posts: 9 |
How is calculated add? Variations are vastness, please look at the attachments: adv ninja trader and your
| [2014-02-02 05:01:01] |
We do not know exactly what you are trying to point out in these images. You have charts of three different calculations. Two of which, we do not even know all of the details of because they are not from Sierra Chart. If you are showing us something, please do not try to have us figure out what you are trying to show us and have us do calculations. We are not going to do that. In any case, we will not comment on the Sierra Chart market statistics in comparison to another service at this time. We are redeveloping all of these and we will have new versions of them out in about two weeks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-02-02 05:07:31] |
We think we know now what you are trying to show, there was a calculation problem on January 31 with the market statistics. This is probably why you notice what appears to be a sudden increase in the Advancing issues minus the Declining issues and then it goes back down. A problem like this is going to be solved with the new versions of these statistics. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-02-02 22:11:28] |
Your $ nshf is exactly the same as ^ ^ Decl ADV minus, they are very big differences. When can it be repaired?
| [2014-02-04 03:01:33] |
We have corrected the data. Re-download the data following the instructions here: http://www.sierrachart.com/index.php?l=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-04 03:01:55
