Date/Time: Sun, 09 Feb 2025 01:08:16 +0000
Sub-instances are not connecting to data feed?
View Count: 501
[2020-08-05 16:42:41]
User34124 - Posts: 279
I get the below error on my sub-instances: (Main instance is working fine)
Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-08-05 10:10:55.468
[2020-08-05 17:48:55]
There were some changes with regards to the Sub-Instances. You need to update to the current version of Sierra Chart. Refer to the information here for how to update:
