Date/Time: Sun, 09 Feb 2025 03:07:40 +0000
Market Depth Data
View Count: 512
[2020-08-05 15:56:44] |
Spartan79 - Posts: 54 |
I have lots of market depth data recorded from CQG and last month SC Denali but under the CQG symbol F.US.ENQH20.2020-02-26.depth. Now I'm on CS Denali and the chart symbols changed to ESU20_FUT_CME.2020-07-31.depth and I can't use old recorded depth data. Can I just change the names of the files from F.US.ENQH20.2020-02-26.depth to ESU20_FUT_CME.2020-07-31.depth for depth data to load on charts with new symbol? What is the proper procedure to go about it? Thank you. |
[2020-08-06 03:39:10] |
No, that will not work because the internal format is different with the decimal position.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-06 03:39:16
[2020-08-06 13:11:26] |
OK thank you.
