Date/Time: Sun, 09 Feb 2025 00:51:50 +0000
[Programming Help] - Datatypes double not int on 64 bit version, here s_SCPositionData
View Count: 743
[2020-08-05 15:32:22]
TeeJay - Posts: 123
Sadly your documentation is not actual ob s_SCPositionData, as it seems you are using double instead of int for all Quantity types. There are also some newer fields in the structure which are not documented. I don't know if they are ready to use yet, but the data type change is productive for sure and it made me some trouble I could only figure out when I checked the sources, as I was insisting that the quantities are int.
Would be nice if the documentation could be updated, thanks
The codepart in scstructures.h is
#ifdef _WIN64
typedef double t_OrderQuantity32_64;//TODO: Use this only when change to SCDateTimeUnix
#else/*
#ifdef _DEBUG
#else*/
typedef int t_OrderQuantity32_64;
//#endif
#endif
Edit : On top of that I have the question what is the reason for sc.GetTradePosition is always returning 1, even if there is absolutely no position for the instrument/symbol? How determine this best then if there is no position? Check Symbol in s_SCPositionData for being empty? I really don't see this as programming help here but rather an explanation how to handle a function that returns a found if there is no result.
Date Time Of Last Edit: 2020-08-05 16:14:04
[2020-08-05 16:43:48]
ForgivingComputers.com - Posts: 999
I have noticed this change also as it showed up in Brett Johnson's ToolKit (which is full of great examples of ACSIL). I ended up casting the PositionData.PositionQuantity to int:
sc.GetTradePosition(PositionData);
int OpenQty = (int)PositionData.PositionQuantity;
I think this was done to support fractional orders for Forex and other markets.
[2020-08-05 16:49:30]
TeeJay - Posts: 123
Yea it is no problem of course if you know but I was curious if I am too dumb putting out an integer into a string after nearly 3 decades of C++ programming or if the function was simply malfunctioning. Luckily, both is not the case.
[2020-08-05 16:58:21]
sc.GetTradePosition returns a 1 when the function was able to get the position, not that there is a position of 1. When you are flat, you have a position with a quantity of zero.
To check the quantity of the position, use the result of sc.GetTradePosition(PositionData):
s_SCPositionData PositionData;
if (OpenQty != 0)
// OpenQty : Positive for Long, Negative for Short
else
// No position
[2020-08-05 17:06:27]
TeeJay - Posts: 123
I did not say that there is a position of 1, I did say that it returns 1, regardless if there is a position or not. So there is no 'not found' or 'no position' return code. That is a difference.
When I am flat I have no position, for real :):)
But regardless of that thanks for your message. I will do it checking against an empty symbol or as you say a zero quantity then. Seems to be the work around for this.
[2020-08-05 17:07:21]
I don't know if you marked this [Programming Help] or if Sierra did. They have stated that they don't reply to posts marked this way, so if you want them to change anything, it may be best to remove this tag.
[2020-08-05 17:14:19]
TeeJay - Posts: 123
I did not, and it is and was no question for programming help.
The first is simply an undocumented change. And the edit was, as I wrote to it, also not a question how I do something primarily as rather the question why a function returns the same value if finding something or not, and why I should check certain data fields to determine what should be done with a return code.
But whatever. I will do it either my way or your way. Both will work. It is just completely illogical.
