Date/Time: Sun, 09 Feb 2025 00:40:58 +0000
Problems with Volume Profile
View Count: 486
[2020-08-05 15:25:23] |
User216960 - Posts: 6 |
I can't seem to set my Vol Profile so that it hold the settings and makes them the DEFAULT settings. It was working before I copied my chart books over as part of my upgraded from WIN 7 to Win 10. Any Ideas? |
[2020-08-05 19:35:56] |
If this is for the Volume by Price study, then just be sure to use the new button to Set Defaults for the study. Refer to the information here: Chart Studies: Using Custom Default Study Settings If this is for the Drawn Volume by Price tool, then refer to the new method to do this here: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
