Date/Time: Mon, 25 Nov 2024 11:40:55 +0000
Rockwell Trading Template for Sierra Charts
View Count: 3963
[2014-01-31 20:37:13] |
amblizniak - Posts: 6 |
Rockwell Trading provides a template with their indicators. One of the indicators is knowing what the Average Daily Range(ADR) is. Regardless of what the market is doing, my ADR stays at 0.0. What can I do to fix this? I have provided a screenshot in the below link via screencast. http://screencast.com/t/ugtUZhaizM Please Advise |
[2014-02-03 19:27:18] |
The easiest way for us to help with this, is to get your Chartbook. Attach it here following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-03 19:34:15] |
Attached is the .cht file as requested.
Rockwell Template SC.cht - Attached On 2014-02-03 19:32:52 UTC - Size: 1.15 MB - 670 views Attachment Deleted. |
[2014-02-05 01:47:51] |
The configuration used in this Chartbook is not familiar to what we have created before. Previously we set up a separate Daily chart for the Average Daily Range calculation. Therefore, we cannot help this Chartbook, but we can create an example Chartbook to show how to compute the Average Daily Range and overlay it on another chart as text. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-05 01:48:41
[2014-02-05 14:51:18] |
Please do so. Thanks. |
[2014-02-06 04:59:32] |
Here is the Chartbook attached.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-06 04:59:44
AverageDailyRangeText.cht - Attached On 2014-02-06 04:59:29 UTC - Size: 66.83 KB - 585 views |
