Date/Time: Sun, 09 Feb 2025 00:45:08 +0000
Problem with chart calculator tool
View Count: 764
[2020-08-05 09:05:15]
User588930 - Posts: 2
Hi I try to mesure the angles' differences between the price and some studies and when I try to use the chart calculator in the studies space it doesn t work.
http://prntscr.com/tucle6
thanks for your help
imageSUPPORTt_2.png / V - Attached On 2020-08-05 09:03:14 UTC - Size: 10.97 KB - 239 views
[2020-08-05 18:45:32]
To understand how the angle calculation is done, refer to:
Chart Drawing Tools: Drawing a Line with a Specific Angle or Slope
We also do not know what is meant by "doesn't work".
Date Time Of Last Edit: 2020-08-05 18:45:56
