Date/Time: Sun, 09 Feb 2025 01:10:58 +0000
Real time SPY quotes
View Count: 950
[2020-08-05 01:52:40] |
steve greene - Posts: 6 |
Whats my exact cheapest option to get real time SPY quotes since I cant use my TD Ameritrade account? thx, Steve |
[2020-08-05 19:40:14] |
You would need to use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. The total cost would be $35.50 USD per month ($25.00 for the data feed and $10.50 for the exchange). Refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
