Date/Time: Sun, 09 Feb 2025 00:47:02 +0000
Rithmic Data Bridge
View Count: 651
[2020-08-04 22:08:11] |
Nathan_Vallinger - Posts: 5 |
Where can I download the Data Bridge file, I could not find the attachment in that post.
[2020-08-05 10:02:10] |
You need to install the Rithmic bridge files: Rithmic Bridge Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-05 16:39:04] |
User342599 - Posts: 1 |
failed conection with rithmic there is no rim subfoulder where to install the rithmic bridge files. |
[2020-08-05 19:21:32] |
You just need to create the subfolder first then. Go to your main Sierra Chart installation folder and create a New Folder named Rim.
