Date/Time: Mon, 25 Nov 2024 10:27:41 +0000
TradeDOM question
View Count: 1356
[2014-01-31 19:54:43]
vectorTrader - Posts: 86
This is a great feature to Sierra so thanks. I was wondering if there is a way to show 2 volume by price studies on the same tradeDOM. I want to show the daily volume profile in one column, then show the current 30 Minute bar profile next to it. If there is a way to do that, could you share it with me? thanks
[2014-02-04 00:48:04]
Yes you should be able to do this. Add 2 Volume by Price studies to the Trade DOM. Set these two Inputs with the study to Yes:
Right Align Volume Bars
Allow Side-By-Side Profiles on Right Side
And of course you will need to set the Volume Graph Period Type for one of the Volume by Price studies to One Period At End Of Fixed Time Length.
We have not tested this, but give it a try.
Date Time Of Last Edit: 2014-02-04 00:50:57
[2014-02-04 15:30:26]
Thank you. I tried that and VbP study will not allow me to select anything else than "from session start to session end". While I can select "One Period At End Of Fixed Time Length", the study reverts back to the former. Please advise.
[2014-02-04 22:35:27]
This will be resolved in the next release.
