Date/Time: Sun, 09 Feb 2025 01:03:35 +0000
[User Discussion] - Scale increment easier access on Toolbar
View Count: 481
[2020-08-04 18:38:04] |
Tonkadad - Posts: 235 |
Is there anyway to have quicker access to "Scale Increment" and the "Horizontal Grid Line Increment" in the Chart Settings? Can it be linked to a control bar so you can have buttons to quickly change the values. Say buttons going from .50, 1, 3, 5, 10, 20 etc with an option to link the "Scale Increment" and the "Horizontal Grid Line Increment" so they use the same values. Example: If I am looking at the NQ futures I like a 10 point scale for both of the increments, but if you switch to a $10.00 stock the bars/data don't have much context until you re-adjust the scale increment down to 1 or .5 I know you can leave it at "0" and it auto adjusts but I like to control the grid lines because I can quickly determine the price movement i.e. 10 points between grid lines on NQ = $200.00 per contract. |
