Date/Time: Sun, 09 Feb 2025 00:46:17 +0000
Cannot Connect
View Count: 573
[2020-08-04 16:39:04] |
Mattc55 - Posts: 97 |
Software version: 2135 64-bit | 2020-08-03 17:21:07.800 Primary Thread ID: 7460 | 2020-08-03 17:21:07.800 Usage end date: 2021-05-26 | 2020-08-03 17:21:07.800 Enabled for: Advanced Features 2. | 2020-08-03 17:21:07.800 Enabled for: Sierra Chart Historical Data Service. | 2020-08-03 17:21:07.800 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-08-03 17:21:07.800 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-08-03 17:21:07.800 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-08-03 17:21:07.800 Enabled for exchange: INDEXES_DATA_BARCHART | 2020-08-03 17:21:07.800 Enabled for exchange2: CME (Trading Account Required) | 2020-08-03 17:21:07.800 Enabled for exchange2: CBOT (Trading Account Required) | 2020-08-03 17:21:07.800 Enabled for exchange2: COMEX (Trading Account Required) | 2020-08-03 17:21:07.800 Enabled for exchange2: NYMEX (Trading Account Required) | 2020-08-03 17:21:07.800 Received 1 data feed usernames. | 2020-08-03 17:21:07.800 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-08-03 17:21:07.800 Current selected Data/Trading service: TT FIX | 2020-08-03 17:21:07.800 Custom symbol settings values: enabled | 2020-08-03 17:21:07.800 Chart Update Interval: 500 | 2020-08-03 17:21:07.800 Intraday Data Storage Time Unit: 0 | 2020-08-03 17:21:07.800 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-08-03 17:21:07.800 2020-08-03 17:21:07 Local computer time | 2020-08-03 17:21:07.800 2020-08-03 21:21:07 Local computer time in UTC | 2020-08-03 17:21:07.800 2020-08-03 17:21:07 Local computer time in SC Time Zone | 2020-08-03 17:21:07.800 2020-08-03 11:31:40 Server time in UTC | 2020-08-03 17:21:07.800 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-08-03 17:21:07.800 Program path: C:\SierraChart\ | 2020-08-03 17:21:07.800 Data Files path: C:\SierraChart\Data\ | 2020-08-03 17:21:07.800 OS Version Number: 10.0 | 2020-08-03 17:21:07.800 Locale Setting: C | 2020-08-03 17:21:07.800 Allowed protected custom studies: | 2020-08-03 17:21:07.800 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:21.679 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:21.679 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:21.679 TT FIX | Disconnected. | 2020-08-03 17:21:21.702 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:21.702 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:22.700 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:22.700 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:22.700 TT FIX | Disconnected. | 2020-08-03 17:21:22.713 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:22.714 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:23.718 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:23.718 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:23.718 TT FIX | Disconnected. | 2020-08-03 17:21:23.730 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:23.730 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:24.730 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:24.730 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:24.730 TT FIX | Disconnected. | 2020-08-03 17:21:24.746 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:24.746 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:25.748 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:25.748 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:25.748 TT FIX | Disconnected. | 2020-08-03 17:21:25.763 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:25.764 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:26.762 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:26.762 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:26.762 TT FIX | Disconnected. | 2020-08-03 17:21:26.782 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:26.782 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:27.777 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:27.777 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:27.777 TT FIX | Disconnected. | 2020-08-03 17:21:27.792 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:27.792 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:28.793 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:28.794 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:28.794 TT FIX | Disconnected. | 2020-08-03 17:21:28.814 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:28.815 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:29.809 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:29.809 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:29.809 TT FIX | Disconnected. | 2020-08-03 17:21:29.826 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:29.826 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:30.825 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:30.825 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:30.825 TT FIX | Disconnected. | 2020-08-03 17:21:30.846 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:30.846 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:31.847 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:31.847 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:31.847 TT FIX | Disconnected. | 2020-08-03 17:21:31.856 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:31.856 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:32.859 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:32.859 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:32.859 TT FIX | Disconnected. | 2020-08-03 17:21:32.870 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:32.870 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:33.871 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:33.871 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:33.872 TT FIX | Disconnected. | 2020-08-03 17:21:33.886 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:33.887 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:34.888 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:34.888 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:34.888 TT FIX | Disconnected. | 2020-08-03 17:21:34.902 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:34.902 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:35.909 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:35.909 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:35.909 TT FIX | Disconnected. | 2020-08-03 17:21:35.920 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:35.920 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:36.918 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:36.918 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:36.918 TT FIX | Disconnected. | 2020-08-03 17:21:36.938 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:36.939 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:37.938 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:37.938 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:37.938 TT FIX | Disconnected. | 2020-08-03 17:21:37.950 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:37.950 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:38.952 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:38.952 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:38.952 TT FIX | Disconnected. | 2020-08-03 17:21:38.965 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:38.966 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:39.967 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:39.967 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:39.967 TT FIX | Disconnected. | 2020-08-03 17:21:39.981 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:39.981 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:40.979 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:40.979 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:40.979 TT FIX | Disconnected. | 2020-08-03 17:21:40.996 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:40.997 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:41.999 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:41.999 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:41.999 TT FIX | Disconnected. | 2020-08-03 17:21:42.012 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:42.012 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:43.014 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:43.014 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:43.014 TT FIX | Disconnected. | 2020-08-03 17:21:43.030 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:43.030 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:44.030 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:44.030 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:44.030 TT FIX | Disconnected. | 2020-08-03 17:21:44.044 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:44.045 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:45.045 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:45.045 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:45.045 TT FIX | Disconnected. | 2020-08-03 17:21:45.058 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:45.058 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:46.057 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:46.057 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:46.057 TT FIX | Disconnected. | 2020-08-03 17:21:46.074 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:46.074 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:47.078 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:47.078 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:47.078 TT FIX | Disconnected. | 2020-08-03 17:21:47.090 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:47.091 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:48.093 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:48.093 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:48.093 TT FIX | Disconnected. | 2020-08-03 17:21:48.104 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:48.104 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:49.106 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:49.106 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:49.106 TT FIX | Disconnected. | 2020-08-03 17:21:49.120 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:49.120 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:50.124 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:50.124 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:50.124 TT FIX | Disconnected. | 2020-08-03 17:21:50.139 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:50.139 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:51.140 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:51.140 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:51.140 TT FIX | Disconnected. | 2020-08-03 17:21:51.152 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:51.152 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:52.152 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:52.152 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:52.152 TT FIX | Disconnected. | 2020-08-03 17:21:52.170 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:52.170 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:53.171 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:53.171 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:53.171 TT FIX | Disconnected. | 2020-08-03 17:21:53.187 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:53.187 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:54.183 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:54.183 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:54.183 TT FIX | Disconnected. | 2020-08-03 17:21:54.200 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:54.201 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:55.210 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:55.210 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:55.210 TT FIX | Disconnected. | 2020-08-03 17:21:55.218 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:55.218 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:56.219 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:56.219 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:56.219 TT FIX | Disconnected. | 2020-08-03 17:21:56.229 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:56.230 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:57.232 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:57.232 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:57.232 TT FIX | Disconnected. | 2020-08-03 17:21:57.248 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:57.248 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:58.245 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:58.245 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:58.245 TT FIX | Disconnected. | 2020-08-03 17:21:58.263 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:58.263 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:21:59.263 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:21:59.263 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:59.263 TT FIX | Disconnected. | 2020-08-03 17:21:59.278 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:21:59.278 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:00.277 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:00.277 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:00.277 TT FIX | Disconnected. | 2020-08-03 17:22:00.294 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:00.294 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:01.292 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:01.292 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:01.292 TT FIX | Disconnected. | 2020-08-03 17:22:01.307 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:01.308 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:02.315 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:02.315 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:02.315 TT FIX | Disconnected. | 2020-08-03 17:22:02.322 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:02.322 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:03.324 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:03.324 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:03.324 TT FIX | Disconnected. | 2020-08-03 17:22:03.342 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:03.343 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:04.345 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:04.345 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:04.345 TT FIX | Disconnected. | 2020-08-03 17:22:04.354 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:04.354 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:05.354 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:05.354 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:05.354 TT FIX | Disconnected. | 2020-08-03 17:22:05.371 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:05.372 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:06.373 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:06.373 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:06.373 TT FIX | Disconnected. | 2020-08-03 17:22:06.385 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:06.385 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:07.387 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:07.387 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:07.387 TT FIX | Disconnected. | 2020-08-03 17:22:07.403 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:07.403 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:08.401 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:08.401 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:08.401 TT FIX | Disconnected. | 2020-08-03 17:22:08.417 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:08.417 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:09.420 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:09.420 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:09.420 TT FIX | Disconnected. | 2020-08-03 17:22:09.434 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:09.434 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:10.434 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:10.434 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:10.434 TT FIX | Disconnected. | 2020-08-03 17:22:10.448 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:10.448 TT FIX | Price Session Server and Port setting incomplete. Check setting in 'Global Settings >> Data/Trade Service Settings'. Format: [server address]:[port]. | 2020-08-03 17:22:11.451 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 17:22:11.451 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:11.451 TT FIX | Disconnected. | 2020-08-03 17:22:11.472 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 17:22:11.473 |
[2020-08-04 18:49:17] |
You have the wrong service selected. Go through the rest of the Setup Instructions for the Sierra Chart Order Routing Service starting at step #9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
