Date/Time: Sun, 09 Feb 2025 01:13:36 +0000
VBP settings
View Count: 1237
[2020-08-04 14:56:25] |
User695019 - Posts: 32 |
hello i want to attach my VBP to the left side of the screen and not right side add you see in the picture. thank you |
Private File |
[2020-08-04 19:23:43] |
The left side is the default position for the VbP, so you should not have any issue with this. Perhaps you need to enable this option: Volume By Price Study: Always Display Last Profile Within View Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
