Date/Time: Sun, 09 Feb 2025 01:27:38 +0000
Session start line
View Count: 1132
[2020-08-04 08:01:34] |
User193814 - Posts: 1 |
Hi, is it possible to have the start of a day's session marked with a vertical dotted line, by default, when loading intraday charts? Thanks |
[2020-08-04 19:20:14] |
Refer to the following for the grid lines: Chart Settings: Show Vertical Grid (Chart >> Chart Settings >> Grid >> Show Vertical Grid menu) and refer to the following regarding Templates: Using Chart Templates: Duplicating Charts / Template Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
