Date/Time: Tue, 11 Feb 2025 01:29:06 +0000
Chart Region - Numbers Bar
View Count: 1190
[2020-08-04 05:42:37]
User991052 - Posts: 33
Hi Support,
Unable to get NUMBERS BARS to display on CHART REGION 2.
Once selected, NUMBERS BARS - display goes blank, including Main Price Graph.
Is there a fix?
Regards,
John
[2020-08-04 17:08:05]
You first have to set the Main Price Graph to be displayed in Region 2, as the Numbers Bars is a replacement for the Main Price Graph. Then when you add the Numbers Bars study, you have to also specify that it is in region 2.
Refer to the following for changing the region of the Main Price Graph:
Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu)
And refer to the following for setting the region of the Numbers Bars study:
Chart Studies: Settings and Inputs Tab >> Chart Region
[2020-08-28 07:07:26]
Hi Support,
Does Sierra offer the ability to " Stack " Chart and/or an Indicator like " Numbers Bar " within the same Chart Window?
I would like to have the ability to display Main Price Graph in Region 1 and Numbers Bar and/or Duplicate Chart in Region 2.
Regards,
[2020-08-28 11:07:31]
You really can only use one Numbers Bars study per chart.
But you can add additional symbols with this study:
Add Additional Symbol
Date Time Of Last Edit: 2020-08-28 11:07:36
