Date/Time: Mon, 28 Sep 2026 22:11:02 +0000
Lines in Replay mode (trend lines etc.)
View Count: 758
| [2020-08-04 01:30:46] |
| User290496 - Posts: 64 |
Hi, I have a chart that was marked up with Lines (to denote support, resistance, trend-channels etc.) in real-time. When using the chart replay function- the previously drawn lines are all skewed off from the angles that were originally drawn, trend-channels are crisscrossed etc. They seem to go back to the correct angles as the replay moves forward in time/ticks. Am I doing something wrong, or is this a known issue? Cheers |
| [2020-08-04 03:31:02] |
Refer to this page: Lines/Rays or Other Chart Drawings Move After Drawing Them One thing is that the beginning and ending Date-Times for the lines must be loaded in the chart for those lines to still be accurate during a replay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
