Date/Time: Mon, 14 Sep 2026 14:41:57 +0000
Connection problem with Rihtmic
View Count: 810
[2020-08-03 22:18:27]
User441045 - Posts: 3
Hello
Since Friday I have been trying to connect sierra chat with Richmic with my Topstaptrader account without success. I have read and applied all the recommendations in the sierra chart forum without success. I contacted Topsteptrader who advised me to ask in this support board to get information. Please could you help me?
Thanks you
Symbol settings could not be loaded because there are no applicable files to load. | 2020-08-03 21:29:02.065
Requested symbol settings for service code scdataallservices. Request ID: 1. | 2020-08-03 21:29:02.065
Reading Internal Order ID file. | 2020-08-03 21:29:02.206
Reading Trade Orders file. | 2020-08-03 21:29:02.237
Reading Trade Positions file. | 2020-08-03 21:29:02.237
Reading Account Balance file. | 2020-08-03 21:29:02.237
UDPListener (952). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Normalerweise darf jede Socketadresse (Protokoll, Netzwerkadresse oder Anschluss) nur jeweils einmal verwendet werden. | 2020-08-03 21:29:02.252
Software version: 2144 64-bit | 2020-08-03 21:29:02.252
Primary Thread ID: 6136 | 2020-08-03 21:29:02.252
Usage end date: 2021-06-10 | 2020-08-03 21:29:02.252
Enabled for: Advanced Features 2. | 2020-08-03 21:29:02.252
Enabled for: Sierra Chart Historical Data Service. | 2020-08-03 21:29:02.252
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-08-03 21:29:02.252
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-08-03 21:29:02.252
Current selected Data/Trading service: SC Data - All Services | 2020-08-03 21:29:02.252
Custom symbol settings values: enabled | 2020-08-03 21:29:02.252
Chart Update Interval: 500 | 2020-08-03 21:29:02.252
Intraday Data Storage Time Unit: 1 | 2020-08-03 21:29:02.252
Time Zone: +00:00:00 (UTC+00) | 2020-08-03 21:29:02.252
2020-08-03 23:29:02 Local computer time | 2020-08-03 21:29:02.252
2020-08-03 21:29:02 Local computer time in UTC | 2020-08-03 21:29:02.252
2020-08-03 21:29:02 Local computer time in SC Time Zone | 2020-08-03 21:29:02.252
2020-08-03 21:29:25 Server time in UTC | 2020-08-03 21:29:02.252
Local computer UTC time and Server UTC time difference: 23 seconds. | 2020-08-03 21:29:02.252
Notice: Your computer's clock is off by 23 seconds. For help with this, press the 'Send for Analysis' button. | 2020-08-03 21:29:02.252
Program path: C:\SierraChart\Rim\ | 2020-08-03 21:29:02.252
Data Files path: C:\SierraChart\Rim\Data\ | 2020-08-03 21:29:02.252
OS Version Number: 6.1 | 2020-08-03 21:29:02.252
Locale Setting: C | 2020-08-03 21:29:02.252
Allowed protected custom studies: | 2020-08-03 21:29:02.252
Rithmic Trading | Port for executable: 50559 | 2020-08-03 23:49:41.625
Listening socket (644). Port 50559 | Closed. | 2020-08-03 23:49:41.625
Rithmic Trading | Starting server: C:\SierraChart\Rim\Rim\DTCBridge.exe | 2020-08-03 23:49:41.625
Error creating process C:\SierraChart\Rim\Rim\DTCBridge.exe. Windows error code 267: Der Verzeichnisname ist ungültig. | 2020-08-03 23:49:41.625 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\Rim\DTCBridge.exe. Rithmic bridge needs installing. To obtain the bridge files, go to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward | 2020-08-03 23:49:41.625 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-08-03 23:49:41.625
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 23:49:41.625
DTC Client socket (0) | CloseSocket call. | 2020-08-03 23:49:41.641
Rithmic Trading | Disconnected. | 2020-08-03 23:49:41.641
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-08-03 23:49:41.641
Date Time Of Last Edit: 2020-08-04 06:33:18
[2020-08-04 06:30:46]
You need to install the Rithmic bridge files:
