Date/Time: Sun, 09 Feb 2025 03:16:09 +0000
dual device use
View Count: 530
[2020-08-03 20:10:03]
User422285 - Posts: 3
hello there I ve got my account on my pc . but when I am on travel I cant sign in my laptop how do I use my account on my laptop when I am on the move ? tnx
[2020-08-07 14:17:20]
John - SC Support - Posts: 37842
You have the ability to use Sierra Chart on two different systems at the same time. So you should not have any trouble using Sierra Chart on the laptop. Just use the same credentials as you do on your desktop.
Just keep in mind that these are separate installations, so you would have to copy the Chartbooks between the systems in order to have the same setup. Refer to the information here to understand what files you may need:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
The one area where you may have an issue is with regards to data. You would want to make sure that you are able to get the data on the two systems.
