Date/Time: Sun, 09 Feb 2025 00:25:23 +0000
How to get real time data on my charts?
View Count: 648
[2020-08-03 17:53:04] |
User810544 - Posts: 2 |
Hi, I activate Denali exchange data feed and Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts. and I paid for them. However, my charts are still delayed. Can you please help me set up real time charts? Thank you. Hiro Teraji |
[2020-08-03 18:50:57] |
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
