Date/Time: Sun, 09 Feb 2025 03:56:09 +0000
Montreal exchange symbols
View Count: 841
[2020-08-03 17:28:28] |
User210422 - Posts: 19 |
hi, I am looking for the montreal exchange symbols. particularly canadian govt bonds and bankers acceptances. Ihave the sierrachart realtime and historical data, but cannot find any of the symbols. Can you add them to the list of availalbe symbols. thanks |
[2020-08-03 21:09:01] |
We see you are using CQG. We will need to set these up.
[2020-08-03 21:16:38] |
We should have this done by the end of the day Tuesday.
[2020-08-10 20:55:32] |
We got behind on this but we are now setting up the symbols. The first one is done. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will see the symbols in File >> Find Symbol >> Futures -Montreal Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
