Date/Time: Sun, 09 Feb 2025 00:01:39 +0000
Trade Pro Academy Charts
View Count: 923
[2020-08-03 17:11:36] |
User805004 - Posts: 5 |
Hello, I had to switch over to a new computer and download the software, however my charts I had built did not download, how to I retrieve my old set up charts? I use the Trade Pro Academy templates if that helps
[2020-08-03 21:07:18] |
If you still have access to your old computer files, then refer to the following: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Otherwise, you would have to recreate your setup from scratch. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
