Date/Time: Mon, 14 Sep 2026 19:06:19 +0000
Graph Draw Types
View Count: 1572
[2014-01-31 14:47:38]
User23815 - Posts: 219
Is there a choice under Chart Settings for Graph Draw Types that allows for coloring the price bars similar to what OrderFlowEdge does? That is, coloring the main price bars differently based on order flow direction of up, down, or neutral. Thanks
[2014-01-31 16:46:27]
No. Refer to the documentation here for what is currently available:
http://www.sierrachart.com/index.php?l=doc/doc_PriceGraphTypes.html
It sounds like you are interested in using the Color Bar Based on Alert Condition study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245
Date Time Of Last Edit: 2014-01-31 16:46:47
[2014-01-31 20:48:24]
Thanks, but I have reviewed the two links and wasn't able to construct what I was looking for. Are there any users that have constructed price bars similar to what OFE uses?
[2014-01-31 23:54:35]
vegasfoster - Posts: 444
If you can provide the formula/logic, then I can try to code it for you.
[2014-02-01 01:53:13]
Thanks but I already have someone who can code SC for me. I was just curious if those particular price bars were a tweak of the stock SC features. I know the logic of what they are supposed to show, but not what is used to get there.
