Date/Time: Sun, 09 Feb 2025 00:13:11 +0000
Market Depth
View Count: 880
[2020-08-03 15:23:45]
Ricardo Zurek - Posts: 18
Hi, I am using sierra charts through my broker (Transact). I have not been able to set up my market dept (it only works in a renge of 2-3 ticks, not for the entire ladder), I already read and applied what is in the "market depth historical graph" document. My question is, if I get the charts directly from you would this problem be solved?
[2020-08-03 19:16:40]
It is not about where you get Sierra Chart from, it is about the data feed. First, make sure that you are getting the full market depth data from TransAct by asking them about it.
But, if you want to change data providers and get your data from us, then start by reviewing the information here:
Real-Time Exchange Data Feeds Available From Sierra Chart
[2020-08-03 19:16:41]
