Date/Time: Sun, 09 Feb 2025 00:12:06 +0000
[Programming Help] - spreadsheet study question
View Count: 647
[2020-08-03 13:21:18]
User873130 - Posts: 47
Hi
How do I populate Time/Date when using spreadsheet study? I am able to populate the open,close,high, low, volume in the .scss file but is not showing the Date Time per bar
Thank you
[2020-08-03 14:02:03]
ForgivingComputers.com - Posts: 999
These are automatic. As long as you have a chart with candles on it, attaching a spreadsheet study to the chart populates columns A through G with Bar Data. Each bar is one row starting at row 3, and working down in descending time order.
The Date/Time of the bar open is in column A. Open in B, High in C, Low in D, and Last (Close) in E. Finally Volume and Trades are in F and G.
[2020-08-03 15:04:23]
in my case, OPEN is in AA, High is in AB, Low is in AC, Last is in AD... Volume and Trades in AE and AF
[2020-08-03 15:37:20]
Those sound like they are coming from a study. Did you look in columns A-G?
imageAnnotation 2020-08-03 103532.jpg / V - Attached On 2020-08-03 15:36:27 UTC - Size: 184.25 KB - 287 views
