Date/Time: Sun, 09 Feb 2025 00:06:23 +0000
Denali data feed problem
View Count: 703
[2020-08-03 13:18:55]
User194713 - Posts: 27
I am currently watching ES futures through two data sources and there is a 8 tick price difference. I think that the problem is on the denali side as the chart countdowntimer on sierra charts was also out of synch. Please advise, is there a problem? Do I need to do anything? Thanks
[2020-08-03 14:33:29]
John - SC Support - Posts: 37842
We are not observing any issues with the Denali feed at this time. If you are still having a problem then follow these instructions to get us your Message Log:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-08-03 14:55:53]
problem occurred for approx 30 mins prior to regular open but I have re-started and all seems fine for now. will keep an eye on it and get back in touch if there are any further problems. thanks
[2020-08-03 17:03:24]
Refer to:
Prices / Data Falling Behind
