Date/Time: Sat, 08 Feb 2025 23:49:56 +0000
Display bug for daily P/L on chart with multiple line chart header
View Count: 561
[2020-08-03 12:02:31]
TeeJay - Posts: 123
when you have your chart header over multiple lines and you activate display of Daily P/L on the chart the values that are on the second line are overwritten by the NPL values
Screenshots are attached, first is when chart is not in focus and second is when chart is in focus.
NPL is only displayed when cursor is over the chart
Date Time Of Last Edit: 2020-08-03 12:03:48
imageSierraChart_64_ULB0RSFpt5.jpg / V - Attached On 2020-08-03 12:02:10 UTC - Size: 102.55 KB - 247 views
imageSierraChart_64_kqkUBAujon.jpg / V - Attached On 2020-08-03 12:02:16 UTC - Size: 109.34 KB - 237 views
[2020-08-03 19:54:00]
This will have to be looked at later on. It is not something we can allocate time to.
