Date/Time: Sun, 09 Feb 2025 00:58:14 +0000
Invalid candlestick values for ^USDINR in SierraChart
View Count: 571
[2020-08-03 11:15:22] |
User876514 - Posts: 2 |
Hi Sierra Chart Team There are invalid values in your source datafeed server for ^USDINR (i.e. USD Vs Indian Rupee) as shown in the weekly timeframe image link. You are requested to rectify the same so that a valid candle stick chart is visible. I have pasted the USDINR chart vide this link http://www.sierrachart.com/image.php?Image=159645240234.png Kind Regards Date Time Of Last Edit: 2020-08-03 11:18:32
[2020-08-03 22:26:29] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
