Date/Time: Sun, 09 Feb 2025 06:00:38 +0000
Cumulative delta day - displayed in figures
View Count: 984
[2020-08-03 10:25:26] |
manfretto - Posts: 117 |
Hi, Is it possible to display cumulative delta day in a row in figures, not as chart? I have found 'Number bars calculated values 1' to display delta but it is not allowed to set for cumulative delta day? |
[2020-08-07 14:18:25] |
John - SC Support - Posts: 37842 |
We think what you are asking for can be done using the Numbers Bars Calculated Values study. Just enable the subgraph named Cumulative Sum of Ask Volume & Bid Volume Difference - Day. Refer to the information here: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-12 15:07:58] |
Ok. It works. One more question. I have chosen multiple metrics in numeric table. Is it possible to decide the order (which comes first the second, etc.?
[2020-08-13 19:23:25] |
Yes, refer to the Subgraph Display Order Input in this section: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-14 11:23:24] |
Perfect.
