Date/Time: Sat, 08 Feb 2025 23:48:27 +0000
DOM for one chartbok but not the other
View Count: 563
[2020-08-03 08:48:25] |
Andre - Posts: 31 |
Hi, I am using one chartbook for intraday and one for ''homework''. On the intraday chartbook, the two DOM's are attached. Now, I opened a new chart book and the DOM's appear in the new chartbook automatically. If i close them, they also close on the intraday chartbook where they should stay. How can i have DOM's tied to one chartbook but not to others? Thank you. |
[2020-08-03 21:05:07] |
It sounds like this is the result of using this option with those Trading DOMs: Window, CB and CW Menus: Window Always Visible (Window) Please confirm if this is the case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-03 21:05:23
