Date/Time: Sun, 09 Feb 2025 00:19:36 +0000
installation problem
View Count: 516
[2020-08-03 07:33:06] |
tobi23333 - Posts: 1 |
Error saving downloaded files to local system. Stopping installation. Check log. Press" install" to retry/
[2020-08-03 11:41:20] |
This is one of the relevant messages: Failed to create folder: C:\SierraChart\DownloadedInstallationFiles\ACS_Source\. Windows error code 5: Access is denied. | 2020-08-03 00:24:50
Refer to the information here about this: Error Messages When Opening Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
