Date/Time: Sat, 11 Jan 2025 07:05:33 +0000
GC Data with SC Real Time
View Count: 1186
[2014-01-31 12:10:29] |
User94740 - Posts: 333 |
Hi SC, gold futures are showing missing volume and always for the same time period. I have tried the usual delete and download as well as updating the symbol, but this happened after upgrading to 1085. Screenshot attached. http://www.sierrachart.com/image.php?l=1391170130333.png |
[2014-01-31 16:31:13] |
We will check on this.
[2014-02-04 00:27:34] |
There was one contract month which is not actively traded in gold which was listed in the Interactive Brokers symbol settings. It has been removed. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings When that is done , then go to that chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-04 00:28:09
[2014-02-09 00:42:49] |
Hi SC, I performed the suggested remedy and yes, the data is now available, but there is still missing data out of Feb. 2011 and half of March 2011. I have attached a screenshot for your review. I checked Barchart.com just to make sure and the data is missing from my charts. http://www.sierrachart.com/image.php?l=139190641560.png |
[2014-02-09 03:11:31] |
We need to replace those affected GC data files on the server. That will be done tomorrow.
[2016-11-17 17:41:10] |
sc, during my back-testing I have noticed data missing for GC from 28.07.2011-29.07.2011. Could you please check? thx as always.
[2016-11-18 00:14:41] |
This will be patched later this evening.
[2016-11-18 10:38:24] |
The missing data has now been added. Follow through the instructions to re-download data for the GC December 2011 contract: https://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
