Date/Time: Sat, 08 Feb 2025 23:57:07 +0000
use x & y constant scale
View Count: 648
[2020-08-03 00:16:14] |
AndyB - Posts: 105 |
hi, i use the "set x&y contsant range" setting in conjunction with "scroll wheel to adjust chart spacing" so i can use it to zoom in and out of a chart. im having trouble finding the keyboard shortcut location for "use constant range" in regards to X&Y Constant Relationship. it seems that this option is not available. what im trying to do is use a keyboard shortcut to turn off "use xy constant relationship" when i need to adjust the spacing, and turn it back on to lock it in. i know this is able to be done by right clicking the price axis, but it would be much easier for me to use a keyboard short cut so i dont have to take my eyes off the charts while trading. i hope this is possible and im just missing it in the keyboard shortcuts menu. |
[2020-08-03 21:27:27] |
We will check on this.
