Date/Time: Sun, 09 Feb 2025 02:47:26 +0000
point chart
View Count: 621
[2020-08-02 19:03:16]
User426295 - Posts: 3
Hallo is possible to have a chart point?
[2020-08-03 19:15:11]
Sorry, but we do not know what you mean by this. Can you give us more information on what a Chart Point is?
[2020-08-03 19:36:11]
Hallo, for example dax 10 point, dax 30 point
the increase 1 point dax 12540 to 12541 this is 1 point
[2020-08-07 14:17:50]
John - SC Support - Posts: 37842
Yes, this is available, it would be a Range Bar. You would need to convert from points to Ticks and enter the value you want in ticks. Refer to the information starting here (note there are several Range Bar types, so be sure to scroll down and review them all to see if there is one you would prefer to another):
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Standard (in ticks) (Chart >> Chart Settings menu)
