Date/Time: Sun, 09 Feb 2025 00:28:49 +0000
Deanli data feed and broker connected on same instance?
View Count: 534
[2020-08-02 12:04:48] |
HeyUgly - Posts: 251 |
DO i need to have the 2nd instance of SC installed if im running Denali data but wanting to execute through my connected broker? Maybe im reading the info wrong on the site sorry if question is repeated |
[2020-08-02 20:04:12] |
No this is not necessary. Here are the instructions to do what you want: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
