Date/Time: Sun, 09 Feb 2025 00:21:20 +0000
Backtest Chartgroup
View Count: 575
[2020-08-02 07:32:41] |
User20202020 - Posts: 18 |
Hi, First, let me start by saying that I used Sierra Chart a very limited amount a couple years ago. I recently started using it again and immersed myself in it and it's an incredibly powerful system. I'm really enjoying working with it and appreciate the constant evolution of updates the Sierra Chart team is devoted to. Is it possible to run a backtest for a Chartbook Group? My sense is that is not possible at this time. Do you have any plans in the future to make that possible? Thank you. |
[2020-08-03 18:57:33] |
You can certainly start replays of all charts within individual Chartbooks, individually. But it is not possible to start them all at the same time. And also this would be just too much processing at once.
