Date/Time: Sat, 08 Feb 2025 23:40:50 +0000
Market Depth Data Problem
View Count: 589
[2020-08-01 16:26:29] |
User432142 - Posts: 44 |
hi, Even if l activate record market depth data on symbol setting for NQ,ES,6B and 6E it was stopped to record for last few days for ES,6B and 6E. Only chart of NQ is open and being used actively. can you let me know the reason. thanks |
market depth.jpg / V - Attached On 2020-08-01 16:24:27 UTC - Size: 164.7 KB - 232 views |
[2020-08-03 18:54:17] |
Make sure this option is enabled: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) And refer to: Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-03 18:55:04
