Date/Time: Mon, 25 Nov 2024 10:57:12 +0000
ACSIL: compare condition not valid, rounding problem ?
View Count: 1382
[2014-01-31 10:06:49] |
User40117 - Posts: 56 |
hi, i'm converting code from another language into ACSIL. an indicator draws support and resistance levels. I can achieve this using horizontal rays. However some of them are not drawn allthough conditions are met when examening values. I compare a price value in between several bars, if they are equal (==) the condition is valid. All values are equal fe 9313.5 when examening (they are copied btw when building the array so they should be equal). Most of the rays are drawn however only a few are not but the condition should be valid... Could there be a rounding problem when comparing these float values ? ty |
[2014-01-31 10:15:43] |
Use this function for comparing float values: https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Functions.html#scFormattedEvaluate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-31 10:33:04] |
ty, but it was (as usual) a coding problem. However i have another question regarding these lines. I would like the line to show up in another chart. Although i have defined the chart number in the settings to display the drawing tools, the lines from my studie are not shown, manually drawn lines however are shown. Is it possible to copy lines created by a study to show up in another chart ? Or do i draw them twice using Tool.ChartNumber = sc.ChartNumber ... |
[2014-01-31 15:02:49] |
Tool.AddAsUserDrawnDrawing = 1; doesn't seem to help either... |
[2014-02-04 00:33:28] |
Or do i draw them twice using Tool.ChartNumber = sc.ChartNumber ... Yes. But refer to the documentation for s_UseTool::ChartNumber here:http://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-04 00:46:36
