Date/Time: Sat, 08 Feb 2025 22:03:58 +0000
TICK-SP
View Count: 1013
[2020-07-31 17:10:53] |
User135370 - Posts: 162 |
I have an AMP accounted and Sierra 5 via AMP, I have access to most Market Statistics however I seem to have an issue with Tick-SP it is not reading real time - In fact not moving at all. Image attached. I'm under the impression that this index is available with all Sierra packages? |
[2020-07-31 18:57:44] |
You should be getting that symbol in real time. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
