Date/Time: Fri, 02 Oct 2026 15:22:03 +0000
Common P/L currency
View Count: 1169
| [2020-07-31 15:55:19] |
| TeeJay - Posts: 123 |
Hi, I trade nearly exclusively US stocks but have my base account currency in EUR. So it would be nice to see my running P/Ls and also the P/L in the trade activity logs in EUR. Now while I read this https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#CommonPLCurrency I have yet to ask if this is really the last truth that I would have to go through all possible combinations in Symbol settings - my trading landscape are essentially all existing stocks - set there manually a currency of USD and then set the common P/L currency to EUR? I hope this is not the truth. Because if I just set the common P/L currency to EUR I get USD values in trade activity log, but with EUR standing next to it. The values stay USD. I hope there is any other solution to this. Thanks |
| [2020-07-31 19:25:37] |
We will set up the currency code for these symbols and we will look into why you are seeing EUR when there was no currency conversion.
| [2020-08-02 11:06:41] |
Thanks, that would be great
| [2020-08-02 11:50:28] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-02 13:11:47] |
That seems to have worked so far, many thanks.
