Date/Time: Sun, 09 Feb 2025 03:26:41 +0000
chart randomly stops refreshing
View Count: 568
[2020-07-31 04:39:56] |
User465507 - Posts: 74 |
Running a chart for ESU20 and have other charts up too. I've clicked 'end' to make sure ESU20 is at the latest bar but for some reason the bars do not update until I click on the chart. Any idea what might cause this?
[2020-07-31 05:37:11] |
Are you using the OpenGL option in Sierra Chart? This is not likely to cause a problem but there could be some issues. Also refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-31 05:37:21
[2020-08-07 03:27:58] |
Hi, Disabling OpenGL fixed the problem. Thank you |
