Date/Time: Sat, 08 Feb 2025 23:40:09 +0000
No orders in DOM
View Count: 561
[2020-07-30 21:00:17] |
User918548 - Posts: 2 |
http://www.sierrachart.com/image.php?Image=1596142496887.png Hopefully the above link with the image works correctly but just in case I only reached out for my DOM only. I don't have any information in reference to bid and ask orders. It only shows the number 1 for both bid and ask inside of my DOM. I'm sure how to adjust this in my DOM setting or whichever settings that would be. |
Private File |
[2020-07-31 21:54:07] |
Market depth is not included with those symbols. Refer to the information here on what is available with the Forex data: Sierra Chart Real Time and Historical Forex and CFD Data Service: What is Included Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
