Date/Time: Sat, 12 Sep 2026 19:35:45 +0000
chart data storage
View Count: 1448
| [2014-01-31 06:34:41] |
| jonno - Posts: 13 |
Hi Is it possible to store chart data into different groups. Could you separate the index chart data from the forex data so that scrolling through them with the +/- symbol is less timely. Also could different chart data be assigned to that specific chart book ie euro CB, gbp CB with only those symbols within. Kind Regards John |
| [2014-01-31 06:42:02] |
Each chart has what is called an associated Watch List. You can add symbols to this list. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#AssociatedSymbolList Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
