Date/Time: Sat, 08 Feb 2025 21:48:06 +0000
SC Feed for two instances
View Count: 529
[2020-07-30 15:46:14]
User353585 - Posts: 66
I'm simultaneously using two instances - One connected to IB, One connected to SC feed.
They both are working fine with the Denali feed.
Now I'm considering to add SC realtime feed for Stocks, Eurex, CFE, Indices data with just one connection support.
I'm going to use
- Eurex/CFE/Indicies feed on IB Connected Instance,
- Stocks feed on SC feed Connected Instance.
It seems like they should work according to https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections
There is one exception to what is described above. Stock data from the Sierra Chart Exchange Data Feed uses a different network connection compared to Futures and Index data. This is done for performance reasons. Therefore, it is possible to receive Futures and Index data from the Sierra Chart Exchange Data Feed in one instance of Sierra Chart and Stock data also from the Sierra Chart Exchange Data Feed using another instance of Sierra Chart.
Are they going to work without problem? I want to check before making the purchase, Thanks.
[2020-07-30 19:22:09]
Yes this is true, this will work as you expect.
